Steve,
I've had a look through your logs and it looks as if the connection to the receiver is being lost for some reason. I although you're getting a bit further now, I'd imagine it's going to be very hit-and-miss.
I'd imagine it's something to do with your wifi set up. When you say you have a hub attached to your bridge, how many devices are attached to the hub? Does connecting the receiver straight to the hub (using a crossover cable or port) help. And what's the model number of the bridge?
Paul
