Mine must be caught up in Customs... I was order #3 and it's not here. Let's hope I'm not on a terrorist watch list!
You bet you are Odd electronics, association with the Hijack guy, obvious suspect Then again, Mark has previously expressed some negativity towards the USPS, so if that's what Patrick used, it might just be normal incompetence and not malice
My progress so far: I got he mainboard out - eventually, that center screw just wouldn't budge! Ended up doing stuff that Rob shouldn't know about Had to reassemble and check that everyhing still worked; all OK. All the pads that'll be under the board are cleaned off with desoldering braid and the boards are completely flat against each other. Now just waiting for the commandments to be handed down before proceeding... Only thing that concerns me is getting that last RAS line in place...
/Michael
