Here is my serial log, if anyone has any idea/suggesion...
If there is anyone present who wants to upgrade the flash, let them speak now,JSA-210, 9590MB w/384kB Cache, CHS=19485/16/63
or forever hold their peace...it seems not. Let fly the Penguins of Linux!=38760/16/63
e000 v1.04h driver i
Copying kernel...
Calling linux kernel...on 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000
l.Q:
Linux version 2.2.14-rmk5-np17-empeg52 (rob@aphex) (gcc version 2.95.3 20010315
(release)) #11 Tue Apr 1 18:49:59 BST 2003
NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel C
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP0001106 ([email protected])
TCP: Hash tables configured (ehash 16384 bhash 16384)re is anyone present who wants to upgrade the flash,
Linux-IrDA: IrCOMM protocol ( revision:Tue May 18 03:11:39 1999 )s of Linux!
ircomm_tty: virtual tty driver for IrCOMM ( revision:Wed May 26 00:49:11 1999 )lling linux kernel...
Starting kswapd v 1.5 done, booting the ke
l.
ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UART:49:59 BST 2003
ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UARTn 11
empeg dsp audio initialisedrial number 10101787)
empeg dsp mixer initialised
empeg dsp initialisedm
Memory: 15
empeg remote control/panel button initialised.2k data, 4k init)
empeg state support initialised 0089/88c1 (save to d0004f80).er cache hash table entries: 16384 (order 4, 64k)
empeg RDS driver initialised
Page cache hash
POSIX con
empeg single channel IDEersit
smc chip id/revision 0x3349
Starting
smc9194.c:v0.12 03/06/96 by Erik Stahlman ([email protected])ersion 4.27 with no seria
b
Partition check:
hdb: [PTBL] [2432/255/63] hdb1 < hdb5 hdb6 > hdb2 hdb3 hdb4
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...change_root: old root has d_count=1
Mounting proc
Starting player
! tags.cpp : 61:Failed to open tags (0xc0041002).
