#260433 - 22/07/2005 11:44
Re: Bugs in V3 A10
[Re: pim]
Quote: Tunes are marked unintentionally, randomly.
This is a feature, not a bug, but it's clearly unpopular enough to remove. The markings are not random, they indicate when the track ended earlier than it indicated it would; often, this is the result of a corrupt MP3. However, if the marking is as overzealous as some claim, perhaps there are bugs in its determination of early ending. FITNR.
Quote: /drive0/var/database3 is read with 512 bytes per read() system call. A larger buffer would speed up the database load.
The actual problem was the dynamic data partition, not database3 (which is read with a single system call). FITNR.
Quote: Version 3 of the player uses utf-8 internally, but the used fonts lack japanese glyphs.
FITNR (for the larger font; it's not really possible to display Japanese in the smaller font).
Quote: Play count display cannot be suppressed.
FITNR.
Quote: Unable to perform station searches using the L & R buttons (remote & front panel).
FITNR.
