If you check out the Disk Upgrade Guide, a Toshiba compatibility problem is mentioned in the "Selecting a Disk Drive" section. The link at the end of one paragraph (leading here) seems to parallel your problem with a resolution.
No longer a stranger, finally a full-fledged member! \:D
