A light bleach to water mix (10%) will kill the mold for a good while. Vinegar also works on items you don't want to risk lightening, but requires a slightly stonger mix (15-20%). As to the moisture, we use a visqueen (sp?) moisture barrier wrapped around the entire structure between the inside and outside walls. Also helps reduce heating/cooling costs.
