I vastly doubt that - new screws always go in during a service. Both myself and David replaced them as a matter of course with no charge!
Well I am not trying to point the finger at anyone. I am nothing but pleased with the service I got from David. It doesnt matter how they got this way really..
I'm not sure what you mean here: are the threads stripped (the screws just turn in the screw holes) or are the heads chewed up?
Your right, I used the wrong terminalogy. They are not stripped, but chewed up so that there is nothing for a screwdriver to grip.
If it's the former, you will need new sled support brackets with good threads.
If it's the latter, you need pliers with 1cm jaws, and you can easily turn the screws by clamping onto what's left of the heads perpendicular to the casing.
New screws are available.
Yeah I am working on the pliers method no luck yet.
Where do i get the scews from?
Chad MKIIa 30Gb Blue
