Windows to start the application and then to have a DDE conversation with it
I suspect that you might be able to fix it by poking around in the registry.
In my experience, whenever I have a problem with documents opening like that, unchecking the "Use DDE" checkbox for that filetype fixes the problem.
In fact, I don't see why Windows defaults to using DDE to open documents so much. I don't see an advantage between that, and simply passing the document name on the command line.
