#282743 - 08/06/2006 21:57
Re: Can't q or control c - causing big problems.
[Re: jbauer]
Quote: I vote yes, change the default behavior so that the serial output goes to the port...
It's not quite that simple. With the v441-v460 scheme, Hijack doesn't work properly unless "Apps use serial". But interacting with the player itself won't work on that setting (by design and necessity).
Quote: I now see a constant incrementing second count and alerts for when I pause and stuff on my serial port. That's supposed to be happening now once I made that change, right?
Right. That's a side-effect of Hijack not being able to work properly.
v461 is now out, and simplifies all of this by removing the player/app separation, same way as Hijack v440 and earlier had it.
