again with the right hijack kernel...
javascript: x()
Code
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v461 ([email protected]) (gcc version
2.95.3 20010315 (release)) #2 Thu Jun 8 15:00:28 EDT 2006
Checking for extra DRAM:
c1000000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 9, serial number 10101748) 16MB DRAM
Command line: mem=16m
Memory: 15008k/16M available (988k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005600).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0x0180
ide_data_test: wrote 0xffff read 0x0180
ide_data_test: wrote 0xaaaa read 0x0180
ide_data_test: wrote 0x5555 read 0x0180
ide_data_test: wrote 0x0000 read 0x0100
ide_data_test: wrote 0xffff read 0xffff
ide_data_test: wrote 0xaaaa read 0xabaa
ide_data_test: wrote 0x5555 read 0x5555
hda: IC35O030ATEA14-0! ! ! ! ! ! ! ! ! ! ! !, ATA DISK drive
hda: IC35O030ATEA14-0! ! ! ! ! ! ! ! ! ! ! !, 8063MB w/1934kB Cache, CHS=16383/1
6/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:06:d
4
Partition check:
hda: unknown partition table
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...fs: unable to read superblock
Kernel panic: VFS: Unable to mount root fs on 03:05
Greetings Helli
