I just replaced an amp and rewired everything
Did this procedure immediately precede the failure? Or did the player work for a while and then fail?
Anyway, check for this problem and this problem.
Disconnect all wires except for 12v constant (yellow) and 12v ignition (orange) and see if the player boots that way.
Yes. I installed the new amp and the problem started immediately after. It was never working with the new amp installed.
Check to see if you haven't somehow accidentally wired up something that is supplying 12 volts constant to the amp remote line.
I also disconnected the power to the amps (from the battery) and tried to fire up the empeg and it still did not work. If the amps are taken out of the equation altogether, doesn't that mean that there is something wrong with the empeg itself? I didn't change any wiring to or from the empeg.
//matt
