#287306 - 29/09/2006 17:20
Re: Can I do this via FTP?
Quote: Um, to do the procedure properly, you shouldn't be rebooting the player while it's set to RWM. Because if you reboot while it's set to read-write, you run into this problem.
Only if you forcibly reboot it by yanking the power. An orderly restart from the player's own menus is fine, as it never unmounts the disk. When the player starts again, the disks are still RW, and it will correctly rebuild and rewrite the database.
Charlemagne^W Peter
