depending on the raid config, you should be able to easily clone the original drive. it's not as easy as just pluging in a replacement drive as you need to restore a partition format.
You shouldn't need to re-install anything. You just need to replace the damaged part. It's hard to walk you through anything without a bunch of info tho. I've done this type of recovery a dozen times.
80gig red mk2 -- 080000125
(No, I don't actually hate Alan Cox)
