That doesn't seem to be the problem. After starting from scratch, I was only uploading about 10 albums at a time, which probably only created 20 playlists at most. When I reach a certain point, I can't upload anything at all. Not even one album.
I've attached a sync log.
Okay. This is an Empeg Mk2 unit, with only 12MB of DRAM.
It is running out of physical memory during the sync.
Not much to be done here, other than enabling swap beforehand (I think this was already tried here, right?), and/or doing smaller uploads.
Perhaps I loaded too much on at a time at first (which I don't think I did, I've done much bigger uploads in the past). But would that cause permanent damage? That log is from trying to sync one single album to the player.
