#298289 - 10/05/2007 12:17
Re: Odd problem with networking on CentOS 5 (Linux)
Quote: Try comparing the values from these "files" on the two kernels:
/proc/sys/net/ipv4/tcp_window_scaling /proc/sys/net/ipv4/tcp_wmem
Then try toggling the value of /proc/sys/net/ipv4/tcp_window_scaling (eg. just do echo 0 > /proc/sys/net/ipv4/tcp_window_scaling).
Or set it to 1, and change the other one to something like this: echo "4096 16384 65536" > /proc/sys/net/ipv4/tcp_wmem
Experiment like that. If nothing much changes, then we can eliminate them from the possible issues.
Mmm.. bad recollection here. It's actually the tcp_rmem setting we should be playing with, rather than the tcp_wmem setting.
In particular, I have used this in the past to work around slowness problems since linux kernel 2.6.17 was released.
echo 4096 87380 174760 > /proc/sys/net/ipv4/tcp_rmem
