Oh, I meant to add: I hardly understand a word of the explanation/fix at the link in the comments above, but if you can understand it, then please have a go at implementing it for us all!
The fix stretches a single pixel transparant gif over the PNG file and resets the imagemap to be applied to the gif. The way the script works does it behind the scenes using the DOM, although you could probably also do it manually in the stylesheet itself. The way the fix works messes up the positioning of everything on the screen, though. I can take a look at it later and see if I can find a manual way of applying the imagemap that will work cross-browser.
