#300513 - 12/07/2007 20:59
Re: How to stop magnetic interference ?
[Re: wfaulk]
Quote: Does your wiring run through a wall near the CRT? This can be a problem in the US, and I can only think that twice the voltage is bound to make it far worse.
Interesting thought, there is a point that is fed from above just to the right of the cab, but if I pull it say about a metre away from that it stays the same. Unfortunately with the way my house is wired I can't easily knock off the ring main and still power the cab, it is possible just not right now.
I know the stuff on the left is the pinball as it only happens when I move the cab back towards it. Now I check the stuff at the top right is pretty much there wherever I put it within the space (maybe a 3m square of floor space).
The more I think about this the more annoying it gets!
Cris.
