#302930 - 13/10/2007 12:16
Re: File system used on Rio Carbon?
[Re: Ezekiel]
Quote: Very interesting. If one knew which parts of the partition table to modify (ie where Cabon puts the # of sectors per FAT), I assume it would be possible increase the number of sectors/FAT listed in each table (the real one and the one used for presentation to Windows), thus increasing the addressable space.
Um, increasing it how? The Carbon already uses all the addressable space on the disk. You can put any size CF flash or microdrive in a Carbon, apply the firmware from upgrader mode, and it will take advantage of the whole size. (Early Carbon firmwares failed to deal with flash CF cards, which don't implement the cache flush command. But the final Carbon firmware version fixed this.)
