 Originally Posted By: tonyc
I think what's happening is that the system doesn't realize that the source and destination mounts are actually on the same partition. So, why not?
Mmmm.. I think I would call that a bug, because clearly it should work as you expected it to.
EDIT: Most likely a bug in whatever program you're using to move the files around.
It should try to use link(2) first, and then fall back on a file copy if that fails.
You might be able to use strace on the command to see what it is doing.
Oh, wait. It's a kernel deficiency. From the link(2) manpage:
Linux permits a filesystem to be mounted at multiple points,
but link(2) does not work across different mount points,
even if the same filesystem is mounted on both.
So that's a shortcoming of the link(2) system call on Linux.
Edited by mlord (18/12/2007 20:06)
