Hi,
I have seen the a similar nomem err with downloading a relatively small database <6 GB. I am using the new v10/v9 build and player software.
The error is "0e80:0 nomem err" or sometimes "0000.0 nomem Err and "0000.1 nomem err"".
The front panel locks up but you can use the remote to get arounsd it sometimes although, it returns quickly.
I have not seen this before on this player with the multiple times I have loaded the system while testing the v10/v9 build/load (probably 30 times) and previously loaded up 45 GB to the drives.
I don't think I have seen it until I started using the Ethernet load method instead of the USB load. I am wondering if it is related to the build or Ethernet.
It would surprise me if it was Ethernet...
I will try a load with USB. Check it out, see if it works.
