I've just installed a new TV aerial, sat dish and multiswitch and now I have to look at installing RF (and probably CAT5 as well) into all the rooms.
The house is a new build, so all the interior walls are studded plasterboard. As with most constructions of this type there are wooden 'noggins' at various heights between the vertical wooden beams which mean you cannot simply run a cable top to bottom as there will be a beam in the way.
It seems the only option available is to run it in trunking in a corner and then break out into the boxes. Anybody got any better ideas?
I'm also a little concerned most of the trunking from places like B&Q are a bit unsightly, has anyone come across something that looks better?
