If you're not using domains then substitute the WINDOWSDOMAIN bit with whatever your workgroup is.
Picking a nit: In the example you cited, with the WINDOWSDOMAIN being part of the username in that format (WINDOWSDOMAIN\Username) then that's never the name of the workgroup, it's always either the name of the domain or the name of the local computer you're logging into.
