Yeah, but this one won't work with either USB or regular serial (caveat - didn't extensively test USB) for flash upgrades. Some timing issue where the bootloader continues booting anyway.
Not that it matters, I finally ripped apart your "bigdisk" images and looked at partitioning scripts, then duplicated them with the disk mounted via a USB adapter. So "pumping" is actually pretty trivial to do. I'll build a kernel at the w/e once I've got the correct toolchain and so forth.
