Oooo. Just noticed you said this model doesn't have an analog input. That may be the key difference between the DCR-HC20 and 30.
If it did have an input, the jack is likely a 3.5mm headphone-type jack. The cable that turns this into composite RCA connectors probably came with the camera, or is available at RadioShack.
