It might be possible, for example, to install a typical IDE cable (with plugs for two devices) and run a standard 3.5 CD and the blank HD that way. I haven't dissected the machine far enough to know what I can do with the HD cable.
The reference manual, available from your link, says that the primary IDE connector is standard 40-pin. So as long as you can find the primary IDE connector, that should work.
I think this is the way I'll try first. I can borrow the IDE cable, power cable, and 3.5 drive.
I think there's only two ways in which they vary: PATA vs SATA at the back (yours is PATA), and slot vs tray at the front.
That's good news- perhaps the machine will end up with a functional CD drive later.
Thanks, Peter!
Thanks, Stig!
I'll tear apart my HP and try that route as a second option. For now, having one machine strewn across the floor is enough! lol
Thanks, Mark!
If it were me, I'd try it. But I'm not familiar with the Linux way of life, so if I'm to do any hand-holding with my friend I'm better off with what I know my way around in. In this case Windows is good enough. Eventually I'll have my chance to get Linux in the back seat. wink
