Thanks, Roger! I'll try the air duster tonight.
I was also thinking of folding a sheet of paper around the stick of memory in order to polish the contacts in the slot. A couple of insertions should be enough to burnish any oxide.
I'd not heard of the paper trick, but it sounds like it might work. With the air duster, the trick is not to spray too close to the contacts -- because the air comes out at pressure, you get cooling and condensation, which isn't always good for components.
I killed a PSU with an air duster last year.
