I repaired SWMBO's broken handle.
The repair was crude, and the final results were not especially pretty, but it worked.
I used a small drill bit (probably a 5/64" or thereabouts) and drilled about a half-inch deep hole into each jagged broken end of the handle. Then I broke a 1" piece off the fluted end of the drill bit and inserted it with a generous dollop of JB Weld into each of the holes I had drilled, applied more JB Weld to the outside of the handle around the break, and held the handle tight together while the epoxy set.
This repair has lasted for more than a year with no problems.
