The inductor and 68pF looks like they are used for matching the input to 75 ohms, and the 470pF is used as a DC block. Are you having sensitivity problems with the switch?
When I last tested it
(still using Frankenswitch v2 in the setup), it looked good except for VHF-LO, channel 6 -- lots of noise
(or reduced signal) on that one.
It was set aside for the summer, since the electromechanical v2 version works fine. But today I was repairing the pre-amp, and took note of the capacitors used there. Thus the query.
Thanks!
