When I had XP, I used for a long time to change metrics as needed, successfully (as mentioned by Bitt). Route metrics are there just for that purpose.
Also, you may set the metric value via GUI (advanced settings of the TCP/IP protocol), if you wish.
I still have some scripts I use to run to get a static IP address, when I need, and you may use that to set metrics as well.
Edited by taym (08/04/2010 15:53)
