Depends on whether the files are encrypted or not. If they are encrypted with the Windows file system encryption then you're pretty much stuck unless you can work out the password.
If it is just that you can't log in then that is fairly easy to bypass. There are plenty of CD boot disk images you can use that'll reset the administrator password for you.
