Are you *certain* that it doesn't work for your purposes now?
Yep. They fixed the "bug" where the Alternate Configuration was active when the primary configuration was talking to a DHCP server. The machine failed to ping it's own alternate config IP when I tried that.
Does win7 permit doing this with an ifconfig command?
Nope. It does have something similar now, but if I try and use the add command on the existing interface, it shuts off DHCP and uses my config as the primary. Subsequent add commands then properly add the additional IPs to the interface. It doesn't appear to support the :1 nomenclature that Linux uses.
The Windows 7 command is "netsh interface ipv4 add address"
