Originally Posted By: jbaur
I couldn't seem to clear out these files properly, so I just ended up fixing the tags once they were improperly copied over with the drag and drop.
Did you try (with MP3TagStudio) the "Mass Clean Up Tags" option before you re-did the tags? That should remove ALL tag information, both v1 and v2, and leave you with a clean slate for applying the tags that you want.
