Many thanks for your help guys...Iv'e woken up now and get the diag info...as follows....what now...can I fix it myself?
˙If there is anyone present who wants to upgrade the flash, let them speak now,
e000 v1.03
Copying kernel...
Calling linux kernel...
Uncompressing Linux.................................... done, booting the kernel
Linux version 2.2.14-rmk5-np17-empeg41 ([email protected]) (gcc versi
on 2.95.2 19991024 (release)) #136 Wed Jan 10 17:19:47 GMT 2001
empeg-car player (hardware revision 7, serial number 80000277)
Command line: mem=12m temp=25
Memory: 10992k/12M available (972k code, 20k reserved, 296k data, 8k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is ffffffff ' '
Logo type is 0
empeg display initialised.
empeg dspaudio driver initialized
empeg infra-red support initialised.
empeg state support initialised 0089/88c1 (save to d0005380).
empeg single channel IDE
Probing primary interface...
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:10:01:1
5
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...
