#342036 - 07/02/201117:40Re: Wall-mounting a large router
[Re: hybrid8]
andym carpal tunnel
Keep in mind that 2 steel L brackets from the hardware store will probably cost you $3 and work perfectly well for a single router as Trevor suggested.
Obviously.
If I were doing the job for myself I'd go to the local hardware store. However if I tried that at work, our group IT manager would probably pop a nut given the value of the Cisco CPE that it would be supporting.
