Hi,
Yes, the boot was correct. The partitions were all created correctly. I was even able to fix the Tags files through a commanded database build. Which almost always doesn't create the Tags files (the only one that is created in the /empeg/var directory is the config.ini file) for large disks (both PATA and SATA).
It was the same as if I had created a set of 250GB PATA disks or a SATA disk (1TB drive with the other converter that nearly works).
Thanks,
