Hi,
Just an FYI...
If you use the cat /dev/hda > /dev/hdc command using the Empeg alone, it takes around 2.5 days each to copy a 250GB Drive. That's 5 days of time for a 500GB file system, but it does work.
Once again, it points to the stability of the hardware design to be able to do this for a continuous time and not have it panic or croak.
Good work guys!
