empeg:/empeg# ls -al
total 4
drwxr-xr-x 4 0 0 1024 Jul 25 2005 .
drwxr-xr-x 15 521 220 1024 Oct 6 01:45 ..
drwxr-xr-x 2 0 0 1024 Jul 25 2005 bin
lrwxrwxrwx 1 0 220 14 Jul 25 2005 fids0 -> ../drive0/fids
lrwxrwxrwx 1 0 220 14 Jul 25 2005 fids1 -> ../drive1/fids
drwxr-xr-x 6 0 0 1024 Jul 25 2005 lib
lrwxrwxrwx 1 0 220 13 Jul 25 2005 var -> ../drive0/var
empeg:/empeg# ls -al /drive0
total 2
drwxr-xr-x 2 0 0 1024 Jul 6 1999 .
empeg:/empeg# ls -al /drive1
total 2
drwxr-xr-x 2 0 0 1024 Jun 2 1999 .
empeg:/empeg# mount
/dev/root on / type ext2 (rw)
none on /proc type proc (rw)
empeg:/empeg# fdisk -l /dev/hda
Disk /dev/hda: 255 heads, 63 sectors, 3899 cylinders
Units = cylinders of 16065 * 512 bytes
Device Boot Start End Blocks Id System
/dev/hda1 1 5 40131 5 Extended
/dev/hda2 6 10 40162+ 83 Linux
/dev/hda3 11 13 24097+ 10 OPUS
/dev/hda4 14 3899 31214295 83 Linux
/dev/hda5 1 3 24034+ 83 Linux
/dev/hda6 4 5 16033+ 82 Linux swap
empeg:/empeg# fdisk -l /dev/hdc
Disk /dev/hdc: 255 heads, 63 sectors, 3899 cylinders
/dev/hdc1 1 5 33232+ 5 Extended
Partition 1 does not end on cylinder boundary:
phys=(65, 15, 63) should be (65, 254, 63)
/dev/hdc2 5 9 33264 83 Linux
Partition 2 does not end on cylinder boundary:
phys=(131, 15, 63) should be (131, 254, 63)
/dev/hdc3 9 11 16632 10 OPUS
Partition 3 does not end on cylinder boundary:
phys=(164, 15, 63) should be (164, 254, 63)
/dev/hdc4 11 3900 31242960 83 Linux
Partition 4 does not end on cylinder boundary:
phys=(1023, 15, 63) should be (1023, 254, 63)
/dev/hdc5 1 3 16569 83 Linux
/dev/hdc6 3 5 16600+ 82 Linux swap
