If your wireless router is like most other wireless routers nowaday, it has one WAN port and 4-5 LAN ports. If you connect your long ethernet cable into one of the LAN ports on the wireless router and the empeg into one of the other LAN ports, it should also work without the second switch. Then the wireless router works as an access point instead of a router, but in most home-cases you don't need the second router anyway.
This usually works, but be sure to turn off the DHCP server in one of the two routers.
