Hi all,
sorry it took so long, but here is the binary 4.0.6 of PHP for the Empeg. Version 4.0.7 will have a new socket API and as I wanted to do mostly socket programming, I thought I'd post a 4.0.7dev image.
However, the 4.0.7dev socket API is buggy and I wasn't able to fix it in a reasonable time.
The zip contains _only_ the PHP binary, you will need a php.ini in /usr/local/lib to tune it. Also, I did not include the PEAR code as this is currently rarely used (and people that use it can easily grab a new copy from CVS).
If you don't have a php.ini and don't know how to get one, this is the latest version from the PHP CVS. To download the file, use this link.
Put the PHP binary into /usr/local/bin or whatever is appropriate for you.
Till
