Can you program Karen to back up only certain *folders* from your system drive?
Better yet, I can program the Replicator to NOT back up certain directories/subdirectories/files in a specified directory, with wildcards even, but the hoops to jump through for that are one of the principal reasons I've been looking at other alternatives.
The other reason of course is the #2 reason in my response to tahir, Once a file is edited and then backed up, there is no going back to the original. Replicator is a simple file copier with minimal tools for scheduling, selecting, and placing the files where you want them saved, overwriting any older files with the same directory path and filename if the modified file's date is newer than the one in the backup. There is no sophisticated management, i.e., master/differential/incremental layering.
