O-Kay ... here goes.
empeg:/empeg/bin# rwm
empeg:/empeg/bin# swapon /swapfile
Adding Swap: 16596k swap-space (priority -2)
empeg:/empeg/bin# fsck /drive0
Parallelizing fsck version 1.19 (13-Jul-2000)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
ext2fs_check_if_mount: No such file or directory while determining whether /dev/hda4 is mounted.
/dev/hda4 was not cleanly unmounted, check forced.
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/hda4: 2451/152000 files (22.1% non-contiguous), 6777232/19451880 blocks
empeg:/empeg/bin# fsck /drive1
ext2fs_check_if_mount: No such file or directory while determining whether /drive1 is mounted.
fsck.ext2: Is a directory while trying to open /drive1
The superblock could not be read or does not describe a correct ext2
filesystem. If the device is valid and it really contains an ext2
filesystem (and not swap or ufs or something else), then the superblock
is corrupt, and you might try running e2fsck with an alternate superblock:
e2fsck -b 8193 device
A quick
cat /etc/fstab reveals:
# /etc/fstab
/dev/hda5 / ext2 defaults,ro 1 1
/dev/hda4 /drive0 ext2 defaults,ro 1 1
none /proc proc defaults
Ooh ... might I need to add /drive1 ???
ls /drive1 does reveal stuff though ... the same structure as /drive0 actually (fids, lost+found, var). drive1's var is empty and drive0 var has config.ini et. al.
At any rate, it looks like /drive1 is part of the root partition. Is this a good thing?
No - wait!
mount reveals the truth (I think):
empeg:/sbin# mount
/dev/root on / type ext2 (ro)
none on /proc type proc (rw)
/dev/hda4 on /drive0 type ext2 (rw)
/dev/hdc4 on /drive1 type ext2 (rw)
So now we continue:
empeg:/sbin# fsck /dev/hdc4
ext2fs_check_if_mount: No such file or directory while determining whether /dev/hdc4 is mounted.
/dev/hdc4 was not cleanly unmounted, check forced.
/dev/hdc4: 2303/152000 files (22.8% non-contiguous), 6783244/19451880 blocks
Next silly question - should this be in /etc/fstab in the first place? (Something's mounting it, at any rate.)
