Dredd... I concur
Tony... As has already been discussed, it is not just as simple as pressing the 0 button. You have to LOOK at the the track you are on, remember where on the CD this came (no track numbers displayed at present) and then skip back the correct number of places to get to the beginning. This doesn't sound so good unless you want me to press pause before I start too!!!
I also listen to mine mostly on shuffle, but if I select a specific album, I want it in its original order from the first track. This is not possible without some looking and remembering.
My opionion is that the playlist's shuffle option should do the following:
If checked then shuffle ALL playlists and children it contains (even if some of the child playlists are set as unshuffled)
If not then play 1st entry and unshuffle.
MK2 Home made smoked 32Gb S/n 090000949
MK2 smoked 32Gb S/n 090000949 MK2a Blue 20GB racked and out of sync
