I'd just like to raise the old chestnut of inconsistent ID3v1/v2 tags.
If you rip your music with an ID3v2 ripper (e.g. MusicMatch), and then edit the tags with a program that doesn't understand ID3v2 (e.g. Winamp), the contents of the v1 and v2 tags will be out of sync.
This causes problems when importing music into emplode or emptool, since they use the v2 tags in preference.
The solution: Use tag editing software that supports ID3v2 tags.
Roger - not necessarily speaking for empeg
roger
