What z modem program?
SZ (send zmodem)
It's built into the developer version of the software. You type sz at the player's shell prompt and then tell your terminal software (such as hypterterminal) to receive a file via zmodem. Warning: This is very slow.
Before you do this, though, you need to be fairly familiar with poking around at the Linux shell prompt. And you need to know what you want to send. The files are located in drive0/fids and they are not named nicely. You can tell by size which ones are MP3s and which ones are data files. Note that the song data you see in Emplode isn't necessarily contained in the ID3 tags attached to those files. Emplode is a separate database and it doesn't write back to the ID3 tags when you change something. So if the original owner made tag edits in emplode, you won't see those changes reflected in the files you grab.
___________
