Yes....and no.
The DSP has 4x5 band parametric EQ. You can chain two 5's and end up with a pair of 10-bands (left/right). As programming the DSP is a pain, and the docs to do so are not freely available (we had to sign NDAs, unfortunately) the first release will probably only have 2x10 support. Still, 4x5 just requires that we have more time to add stuff to the code - it'll happen if there's demand, the hardware is capable.
Hugo
