It kinda sounds like the antenna amplifier in your car suddenly quit working, or the antenna plug became broken or frayed internally.
Also there is a known bug in 2.0b3 where sometimes the tuner doesn't properly activate the power antenna wire. See if different combinations of booting, sleeping, etc will wake it up and make the power antenna wire come on.
Yeah, but he says he is getting 5 bars of strength, and it used to work fine. Everytime that the power antenna has not worked for me, the signal indicator reflects the lesser signal.
So his pigtail should be wired correctly (although I guess a wire in it could have come loose, but that doesn't really jive with full signal strength.)
Synergy
[orange]mk2, 42G: [blue] mk2a, 10G[/blue][/green]
I tried Patience, but it took too long.
