I got it to move properly...What is happening is when you go to delete a playlist entry, and you hit that little checkbox to delete the file along with the playlist entry, it's remembering that...And when it goes in to delete the old playlist entry, it checks to see if you told it to delete the file along with the playlist entry...Quick workaround, go in and delete a junk song/playlist. when it comes up with the box that asks if you want to delete the files along with the entries, uncheck it. Then moves with work fine(at least they are over here).
--Ben
--Ben
78GB MkIIa, Dead tuner.
