You can use a two channel amp and get excellent separation DEPENDING on your speaker placement. The advantage of a 4 channel amp is to utilize the fader control and wonderful 4 channel eq built into the empeg. Four channels will give you the ability to "shift" your soundstage frontwards or backwards. I would recommend a 4 channel amp for these reasons.
