Actually, Windows doesn't put the files into alphabetic order. I had to actually write code to sort them.
If you've got your track numbers filled out correctly in the ID3 tags, you can use the "Set Playlist Order" button/menu option to sort the playlists into track number order.
I'd recommend putting the track numbers in the filenames. This means that they're in the right order for other applications, also.
