Wouldn't it be a better (techie) solution to map the pixel brightness values one down the scale in dimmed mode, ie. Bright->Normal, Normal->Dim? This means you'd not loose too much contrast, only low illumination definition on the pixels illuminated as Dim.
This (I would have thought) could be done reasonably easily in the s/w.
To be honest, at night I want the driver behind to see the graphics properly...
{8^)
One of the few remaining Mk1 owners... #00015
